Have a 94 Ford Tempo GL 2.3lt 4 cyl that the blower for the AC has stopped blowing. I have tried to replace the blower motor and the resistor and still the blower will not blow.
Any suggestions?
Check the fuse and make sure you have 12 volts at the blower wiring connector.
When you have done this and if you find that you have voltage at the motor, then check to be certain that there is a ground from the motor to the chassis of the car.
Invest in the purchase of a test light probe for under 10 dollars and then use it to check where power is getting to. The real problem may be with the blower relay or speed selector switch. The test probe will tell you what is going on.
