94 civic electrical
the problem is that the 30 volt fuse under the dash keeps blowing right after i replace it. it controls the part of the consoul lights and the lights on the back of the car. this happen one before a few months ago with the same fuse when i was movin around my cd player deck and it blew then was fine after replacing but now the problem is back? could it be a tuching wire in the back of the player?
Something is causing a short. Since things seemed to change with the movement of the CD player that would be the first place to look for a wire problem.
If your car is blowing a 30 amp fuse, something is seriously wrong. You have a major short circuit somewhere. I’d check whatever you were moving around before and look for a bare wire or poor connection.
NEVER use a higher amp fuse than what was originally in the circuit.
