'94 Chevy PU 1500 Std Cab HVAC dash control panel
Had to replace Control panel (stolen). Found used one but the ID markings on buttons are not visible at night with lights on. What is problem? Is it possible to make a DIY repair?
Please advise if additional info desired/required.
Thanks
Did the wiring for the lights get connected properly and did you check to see if there is voltage getting to the dash lights when the lights are on? If there is voltage getting to the panel then the lights are most likely burned out and need to be replaced.
Problem solved. Bad bulbs.
Thanks
Jeb
Glad you got it fixed. Thanks for the feedback.
