i have a 93 ford taurus with 83k miles and the air bag light flashes in a 3 flash then a 4 flash pattern. does anyone know whats wrong?
A short in the driver’s airbag, or in the wiring or connectors going to the driver’s airbag. This includes the clockspring.
My Ford Ranger does the same thing every once in a while. I disconnect the plug under the seat of the passenger side and clean the contacts. Problem goes away.
Are you sure that was a code 34?
3 flashes 4 flashes then a long pause
Sorry, I was asking wizard that. That shouldn’t be the right code for a side airbag.
okay, it’s 3 flash pause 4 flash then a long pause and starts over again
