The current symptoms of this car is no power past 3k RPM. Even with the clutch pressed in (or in neutral) I cannot rev past 4k.
What I’ve done so far.
New-
Plugs
wires
coil
distributor
rotor
cap
fuel filter
Compression is 150-170 all cylinders
Does not seem to be missing.
I’ve taken off the Cat and there was not change.
Background:
This is after the car was garaged for 8 months with a half a tank of gas. The car started right up and I drove around 5 miles or so with no ill effects. Car performed just as well as when parked. Good power across all rpms. Then I topped off the tank with fresh gas. Not 200 ft of driving later the car was firing only on the #3 and #4 cylinders. This is what prompted all of the new parts and compression test above. None of the new parts fixed the dead cylinders. When checking if the injecotrs on 1 and 2 were firing i unplugged and plugged in all the injector connections. Now the car runs on all 4 cylinders. But, I have the above power issues.
Good luck everyone. I’m running out of ideas and I really wanted to donate this car to a family we know that could use it.
-Dave
