91 camery,e.f.i.fuse keeps popping on start of engine
why is this happening.replaced ignition mod,coil is fine,new dist & rotor
I would look for a short in a wire. Look for someplace where the insulation is compromised and where it may be touching some part of the engine or body.
poss short in the main relay,this wakes up fuel pump,and inj at start.you definatly have a short to ground.
