How do you replace a front wheel bearing on a 77 chevy Pick up?
Front?? 4wd or 2wd???
4x4 or 4x2?
Either way, you have the old style serviceable tapered roller bearings which may just need to be cleaned up and repacked. It’s pretty easy to do, but the prcedure is differenct depending on weather it is a 4x4 or not.
two wheel drive. Sound like the bearing is not pressed into the wheel?
Thanks a lot this helps
