2021 Nissan Frontier - Vibrates when idle
Excess vibration in steering wheel at stop sign or red light with foot on brake and transmission in gear (forward or reverse).
Could be a slight idle misfire. The first step is a scan tool diagnostic code check. Is the check engine light on? Seems unlikely for a 2021, but if you got unlucky or your driving style is quite aggressive, another possibility is faulty engine/transmission mounts. I’m guessing you have an idle misfire caused by an overly learn mixture. You might ask your shop to also check the fuel trims as well w/their scan tool equipment.
Your vehicle should still be under warranty. take it to the dealer
Agree unless the wrong year popped up.
Another one for take it to the Dealer for warranty…
Take it to your dealer and have them check for the TSB on the intake manifold.
Does that cause a vacuum-type leak & a lean mixture?
It would tend to, yes.
A bad crank sensor can cause a rough idle.
