2020 Hyundai Kona - Engine issues
oil loss engine noisy vavle or other noise. 2times now first time timeing chain cover leak ,now back next wk for another check oil still leaking. and noisy engine
Get back to the dealer immediately for warranty work.
The engine is very likely making noise because there’s not enough oil. How long have you owned your Kona and have you been keeping up with maintenance? That will be a large factor when it comes to getting a warranty repair.
Only have 5600 miles on car just had oil change 2months ago
You should be in the clear then, assuming you’ve been checking the oil regularly. Best of luck.
