2019 Toyota RAV4 - Odd malfunction
SRS malfunction after 37000 miles.
No accidents. It starts once per 2 weeks, every week, every
3rd day and now everyday.
Seems like, because of driver seat belt.
Do you have any water leaking into the vehicle? if so I have found the following…
As noted by many other 2019 thru 2021 Toyota Rav4 owners, there is significant water leakage intruding into the vehicle passenger compartment. I can confirm that the water intrusion that my vehicle has sustained is leaking through inadequately sealed holes for clips that are part of the Roof-rack side rails. And that this severe water intrusion is likely damaging the electrical system connectors associated with the vehicles Side Impact Air Bags and possibly the tire-pressure monitoring system (TPMS) connectors in the side body pillar areas. Our local Toyota Dealership Service Center is aware of this problem
2019 Toyota Rav4 Water Leak at the Headliner | TOYO Headquarters
Good idea above. Another, make sure there’s nothing on any of the seats other than people. Something like a briefcase on a seat might possibly confuse the SRS computer.
Warranty on the restraint system is 5 years/60,000 miles.
A briefcase should not cause a passive restraint system failure.
Example of a problem (water leakage) caused by something 90% of owners never use (roof racks) but get charged for. Kind of like sunroofs.
