2019 Lincoln MKC - Should I buy?
would you recommend this car to buy. If any what are some issues you have had with this car?
Suggest to tell us more about the car’s configuration. Which engine? L4 2L hybrid, L4 2L turbo, v6 3L turbo? FWD or AWD?
In general it looks pretty good from what I can tell , but on some configurations at least it appears there’s been some computer re-programming needed, and possibly some sort of problem w/the rear view mirror. Definitely make sure all of the recall/customer campaign work has been done.
Knucklehead diy’er opinion only, no experience with this make/model.
George is correct, knowing the powertrain combo helps some, different engine/trans combos can/will have different issues…
BTW you have been redirected to Car Talk forum and probably not to many members here will have your combo to help you with your decision… but the best advise I or most anyone else can give you, is get a detailed prepurchase inspection from a mechanic/shop of your choice, the vehicle needs to be check for any loose and or worn parts, rust, frame/unibody damage, unwanted modifications, basically the over all condition of the vehicle, now no one can guarantee if/when the engine, trans, driveline, AC, modules will go out, but they can check for leaks, funny noises, codes pending or history… Most any good mechanic can pick a part a vehicle pretty good if given time (money) to do so…
Good luck…
