I have 182K km with my CRV 2018. Two months ago, a strong noisy appeared when the speed is over 65 km/h. I visited 3 dealers find the reason, and each gave me a different answer and explanations. After 2 mo the problem still there, I changed the tire with winter tire and the noisy still there. DID someone had this problem and, if so, what you done to eliminate the source of noisy. Thanks.
Noise might be wind related. Could be around windows or plastic body parts such as the bumper covers. Inspect everything for gaps or misaligned body parts. Does not take much force to break some of the mounting tabs.
What KIND of noise? Whoosh? Growl? Squeal? Tapping? Flapping?
We can’t hear it from the internet so you must describe it if you want help.
Mustangman beat me to it… so +1
Can you make a video of the noise and post it on here??
Do you hear the noise from the front, back center of the vehicle and which side??
Does the noise change levels when you are driving in a curve right or left??
What was the 3 reasons given by the dealers??
