2018 Chevrolet Equinox - Ongoing issues
I own a premier 2018 Equinox 2.0 turbo, I have had problems with the fuel injector since I bought it. 2 fuel injectors later, a cracked spark plug and after picking up again 3 days later it broke down again.The engine light is back on and traction support light on again, chugging at 35-40 miles an hour, the 4th time in for same issue, but this time I was told there is water in the gas.GM will not repair. A 2018 Equinox with 5200 miles on it?? Has anyone been having fuel injector problems similar and any suggestions?
Julie, you may think you are reaching out to other 2018 Equinox owners but that is not the case here. This is the Forum part of the Car Talk web site. Look in your manual for contact numbers and take your problems to corporate and make copies of all your work orders. You do have the right to use any Chevrolet dealer for repair.
