2017 Honda crv 1.5 turbo. it has 69,000 miles and has had warning lights on dashboard go off randomly i reset it and in a few days they come back on my number starts with 5J6rw. does anyone else have this problem. thank you
That is the start of your VIN which means nothing about the codes . Post the actual codes and you will get better help.
The engine diagnostic codes usually start with the letter “p”. Like p0420 means the catalytic converter may not be functioning properly. You can type a p-code into Google and sometimes get some pretty useful info also.
Check with the dealer, there is a service bulletin that covers an issue similar to this
