What kind of noise?
Is it a new noise that it didn’t make before?
Have you had the brake pads replaced yet?
If so, did the noise start right after replacement?
Corvettes use high performance brake pads that can be noisy and do wear out much faster than regular brake pads. The drilled and slotted rotors are also hard on the pads. You may need new brake pads and rotors, but it is best to have them inspected by a qualified mechanic. Worn pads and rotors are not covered by warranty and they will be very expensive if you need them.
