2016 Volvo XC60 coolant level low message
I have a Volvo XC60 2016. Every year, I get a message of engine coolant level low. It never happens on my other car. I talked to dealer and was told it’s normal. I just want to know is it normal?
Is the coolant low? The warning is there for a reason. That reason is; If coolant is low, the light comes on, you add coolant, the light goes out. That’s how it is supposed to work.
If the coolant is low, you add, and then need to add some more OR of the coolant is OK but the light is still on, you have a problem your dealer should address. 2 year old car, still under warranty.
