we took the 2016 corrolla into the dealership for a 2yr service check at the same time they did a software update.  about a mo later the RPM would kick up to 5000 RPM w/no acceleration
this would happen quite often.  from a dead stop you can accelerate and the RPM would kick up and  no speed took the vehicle back to the dealership 3 times they say they can’t duplicate it.  even got corporate involved to no avail. also because the vehicle is always running at a high RPM the gas milage has dropped about 11 MPG.  we also asked the dealership to put the software back to what it was since we didn’t have a problem before  they said they can’t do that.  any suggestions.  thanx
Are you saying the rpms jump up but the car doesn’t speed up? That sounds like a transmission problem. And happening a month later makes me doubt it’s the update causing it. Can you not duplicate it?
