2016 Subaru Impreza Sedan WRX - Rattles at slow speeds
rattling sound at rear at slow speeds
If you are asking for help, then does it make the noise anytime or just going over bumps?? When taking off, when braking?? Turning??
Check for loose or broken exhaust…
Bad or broken rear sway bar end link or bushing (if any)…
One of the many rear suspension parts…
Something inside the trunk loose…
But from the very limited description, it is going to be hard to guess at what is wrong…
Make a video (more then 2 seconds lol) of the noise…
Might be exhaust system noise. Maybe the rear part of the exhaust system has come loose from its moorings. Unless you can find something rattling around in the trunk, your best bet I’d guess is ask your shop to put the car on their lift and take a look for anything loose on the underside.
I vote heat shield
