We have had a problem with the low beam lights on our Sorento for as long as we have had the car for two years. We need to drive at night with the high beams on in order to see the road. At first we accepted the idea that we would have to get use to it but have seen and talked to others with similar issues. If there is not a recall for this can I get a fix suggestion? Have tried changing bulbs with no improvement.
First, bring it in for a headlight alignment. Then you might want to check into HID lighting which I believe is pretty expensive.
