2015 Jeep Patriot stalled occasionally at red lights
Jeep looses RMP for a split second while driving 80 - 100 KM does this randomly. Also has stalled 2 times while at red lights. Starts right back up, no engine light on, no error codes…
Those are indications that the crankshaft position sensor may be starting to fail.
https://www.rockauto.com/en/catalog/jeep,2015,patriot,2.4l+l4,3309745,ignition,crankshaft+position+sensor,7196
The tach signal is generated by the crank sensor. And if the sensor fails from engine heat when the stopped, the engine will shut off.
