Transmission started juddering somewhere in the 80-100k range. They said it needed the Judder TSB fix. Flush the transmission and software update $380. Frustrated that Honda is hiding these transmission issues behind a TSB and not letting owners know about it.
I would suggest voting with your feet and making sure your next car is not a Honda
Transmission fluid should be done every 30,000 miles as routine maintenance anyway. They are not necessarily “hiding” behind a TSB, not all owners will experience the shudder.
