control decent fault brake light on np speed control abs modulke?
Steve , that post makes no sense at all.
Help us help you Steve 99. Slow down and tell us as much as you can as clearly as possible.
Hill Descent Control Fault light is on. ABS light is on. Possibly a fault in the ABS control module, maybe a wheel speed sensor.
A decent code reader will give you ABS codes. Start there.
