2015 Dodge Ram 1500 - Dead battery
I have a 2015 dodge ram 1500 was fine yesterday and this morning it wont even click when I turn the key
will not jump start either
Do the dash lights come on?
There is a power wire that ties between the battery and the fuse panel under the hood. Make sure power is getting to the fuses in that panel. Also make sure the battery connection to chassis ground is making good connection. If that is all good and you still have no response then check the power connection between the panel under the hood and ignition switch.
