2015 Chrysler 200 - Trouble starting
trouble starting. then when started unable to shift gears and stayed in neutral.
What were the circumstances when the car wouldn’t start? It’s remotely possible your shifting problem is caused by a low battery. Have it fully charged and see if it makes a difference.
nothing was wrong with the battery at the time. now even when i start my car i cannot turn it off. also i cant drive even if i put the gear into drive or reverse
