Fuse location for Cruise Control…?
Look in your owners manual. Should show the location of the fuse boxes and each fuse.
Cruise control switches are usually a 5 volt circuit powered by the PCM, a fuse is not needed.
If the check engine light is on that is the reason the cruise control has been disabled.
Why do you ask about fuse location ? Tell the people what your problem is and Nevada asks ’ is the check engine light on '.
