I would suggest that you spend a bit of time poring over the factory maintenance schedule, because there are a number of important items that you have skipped over the past 10 years.
In addition to the engine’s air filter being very much overdue for a change, you should change the cabin air filter. And, you are due for a spark plug change. There could easily be a bunch of other suggested maintenance procedures, including the inspection of things like CV joints, brake lines, and exhaust system.
I would also flush the brake fluid, and–if the vehicle has an automatic transmission–I strongly suggest that you have its fluid changed.
