my drivers seat will not slide backward
Check the track for an obstruction.
Can you hear the seat motor when you press the button? Will it move forward?
Any luck with your seat? Mine is doing the same thing.
Electric or manual seat?
Appears to be a common problem with these, bad seat switch. One owner’s theory is that the limit switch gets stuck and thinks the seat is already all the way back. Some have had to replace the same switch more than once.
