VVT actuator - Honda, any real fix?
Not sure what you mean by any real fix??
The real fix is to replace the appropriate part that needs replacing, then make sure you are using the correct oil, changing on maintenance schedule, and making sure the oil level is always in the safe zone, so topping off when/if needed…
If you are asking for help, then it is best to start with what codes are for the CEL??
Welcome to the forum…
