2014 Ford Escape knocking sound
knocking in rear on a 2014 ford escape, speeds up as tires turn
Lok for a dmaged brake rotor, tire coming apart, wheel bearings… if it is AWD (you don’t say, well, anything about the car) if could be a drive axle failing or loose. You really need to lift he car and start looking for “loose”
