Drivers side power seat keeps blowing 40 amp fuses!
Drivers seat motor or heater wiring has a short to ground, or a big bind. Don’t just put a 60 amp in there.
How often do you move the seat? My wife had a dodge stratus with power seat’s worked good for about 3 year’s when we both drove it before it started acting up. Found out the problem the wiring harness was under the seat I am 6 foot 2 & she is 4 foot 11 she needed seat all the way forward & I needed it all the way back all that movement caused wiring to short out.
Thank you for your response I will check that out.
