Will a t125/70D16 donut fit for a 2014 dodge cabiler
No way to answer this because you did not tell what the donut came of what vehicle . Just go to a local tire store and let them tell you .
The tire size doesn’t need to be exact, the wheel must fit the vehicle. The bolt pattern, hub center diameter and brake caliper clearance must be correct. If you don’t know which vehicle the spare came from, you will need to see if it will fit your vehicle by installing it.
