Is there a way I can fix/repair the exhaust rattling noise by the heat shield? It is annoying!!!
A welder, a hose clamp, or stainless steel wire may be used to tie down the heat shield. What you use depends on the geometry of the attachment and the tools you have at hand. Or take it to an exhaust shop and have them clamp or weld it.
