2013 Nissan Frontier - Stuck windows
some times my 2013 frontier drivers side door windows stucks up and down with the control
Get it repaired before it stops moving at all.
True could be sticky sometime
Agreed, do not lower the window until repaired.
Welcome, and thanks for warning me before I try your windows.
Welcome, and thanks for … well, I don’t know.
What is this product True ? And why is it sticky sometimes ?
I think that the True product on the right is probably always sticky.
:wink:
Ask shop to remove interior door panel , clean old lube away, then apply fresh lube to the window-regulator. & Make sure all window regulator fasteners remained fastened. I’ve noticed, esp on my Ford truck, the fasteners tend work themselves loose over time. I find them laying at the bottom of the door.
Try dry silicone spray on the window channels.
Remove the doors, we don’t need no stink in’ widows.
