ac works off and on high pressure side is 250 to 300 psi with a standard 18 oz measured charge has good air flow what else is the problem?
Since the vehicle doesn’t utilize a CCOT AC system, the high/low side pressures should be constant.
The only thing that can cause a fluctuation in the high side pressure is a faulty expansion valve.
