back up camera in my 2013 hyndai elantra just stopped working. it comes on but no live picture
If You are having issues with the backup camera on the 2013 Hyundai Elantra, . One of the reasons the backup camera will not work can mostly be associated with a blown fuse. Yes, that’s right, a tiny fuse can prevent the camera from working. The good thing is that replacing the fuse is inexpensive and it takes less than a minute. Another reason why the backup camera won’t work is due to loose wiring from the camera. I would recommend to inspect the wiring and check if any are loose or if any of them are damaged. If they are, all You would need to do is replace the wiring or reconnect it.
When you say “it comes on”, you haven’t said what part of the system is on. I presume you mean the display is on, but gets no signal. Yes?
