have a 2013 honda accord when i go over a bump the car suspension wants to get loose under definitely something is wrong honda dealer at brick ell have replaced the rack and pinion twice both tie rods there something wrong with the sruts parts bearings dealer needs to check the studs
Check the stabilizer end links because they are probably worned. Very common parts to replace on front wheel drive vehicules.
Try a shop that specializes in suspension work and wheel alignment.
Stabilizer bar end links have nothing to do with steering.
The end links connected to the stabilizer bar, prevents the vehicle from too much body roll when cornering.
