2013 Dodge Durango shuts off on cold startup
2013 dodge Durango starts and shut off when cold then will run on second or third time. Some smoke at start up. has 60,000 miles
Is the check engine light on? What are the error codes? Which engine?
no warning light at all V-6 engine
Can you explain a little more of your problem?
You turn the key and the engine cranks but doesn’t start? Starts but dies? Takes 2 or 3 cranks and starts to keep it running?
Or what?
