I have to manually shift it from first to 5th as if it were a standard when I try to put it in drive it will jump to about 6000 RPMs jump from drive into 3rd gear when it gets stuck in drive it won’t shift past 2nd gear after pullover turn it on and off 7 times before it will be over shift
That would indicate severe slippage, but there could well be other issues with the transmission.
I assume that you already checked the trans fluid, and filled it to its proper level.
Am I correct?
What was the color of the fluid on the dipstick?
If this is anything beyond a low level of trans fluid, then you need to take the car to an independent trans shop (NOT a chain-run place like Lee Myles, Cottman, Mr. Transmission, or AAMCO) for diagnosis.
I hope that I am wrong, but I suspect that you will need to overhaul the trans.
When was the last time the transmission fluid was serviced?
