I have a drive train vibration issue that I understand has been an issue with my make/model. Specifically, I feel a pronounced vibration with an associated hum starting around 50 mph. Has anyone experienced this issue? If so, what’s the fix?
awd? 2 piece rear driveshaft? inspect the support bearing if it has one. since most awd vehicles have one i would start with the driveline
Thanks - I appreciate the guidance, TC
4 months later . What does your post mean , problem solved or what?
It means I just saw your response a few minutes ago, and I was thanking you for it.
