2012 Toyota Highlander thumping after brake job
I had a four wheel brake job (1st ) with rotors turned. After leaving dealership I heard and felt a knocking or thumping sound every time I turn the wheel to the right even while backing up. Thank You
Then you should take it right back where you had the service. They might have left something loose. In fact, you should have done that after the second knock or thump.
