We had problems with our motor about 3 years ago, and it had to be basically rebuilt. Under warranty. Then a year ago the transmission went out at less than 80,000 miles I believe. It is in the shop again for having a shift issue into 3rd gear going approx. 35 miles per hour. If it has a year warranty on transmission that will soon expire. Any other complaints in that area with this vehicle.
Apparently, yes.
CSA
So how often have you had the transmission serviced. The answer should be every 30k miles…
