Vehicle drains battery sometimes overnight other times you will be driving and the battery voltage will drop the Vehicle will start losing power then die three new alternators and two new batteries and main computer
make sure your brake lights are not staying on after you get out of vehicle. if they are you have a bad brake light switch. it can stick intermittently so check them a couple of times.
