2012 Chevrolet Impala - Grinds
and system comes on with stabilizer and traction control. Grinding noise at low speed when making turns or going over bumps. Both hub bearing assemblies have been replaced which has not fixed the problem. Hopefully you can guide us as to the next step. Thank you
Would you start over asking your question? It seems like the top half was cut off. Please add some info about your car as well.
Does the grinding happen with and without applying the brakes?
2012 chev impala makes. Grinding noise when making sliw sharp turnd. Stability warning light comes on. Had wheel hub assemblies replaced on front. Did not help grinding noise . any suggestions?
