2011 Kia Sorento - Radio trouble
why does my radio come on then go off and then back on and off again?
you can try this first…
How do you reset the radio on a 2011 Kia Sorento?
Look on the front panel of the radio for a small hole (supposed to be near the upper right corner). If you find one, straighten out a paper clip, and while the radio is on, press the button under the hole. The radio should turn off, and then reboot (like a computer).
if it doesn’t work from what I have read from others with this problem is it seems the only other option is to replace the radio.
