my key gets stuck in the ignition, so I have to start the car, and shift too reverse or drive, then to park again, then its okay, I’m sure what the issue is. Please help !
The cable or switch between the transmission shifter and the column lock needs adjustment. Most shops can do it, as can the dealer.
