Shift to park indicator light remain on after the car is turned off
It sounds like you’re saying the indicator that tells you what position the shifter is in stays illuminated after the ignition is off. You could have a faulty ignition switch that’s not telling the display the ignition is off. Another possibility would be a failing Body Control Module. They can cause all kinds of mysterious symptoms.
