2010 Honda Odyssey - Timing belt and water pump?
Recommendation for timing belt and water pump service? 3.5 litre v6.
Yes it is recommended, if you don’t do the timing belt by the age/mileage specified by Honda you are risking catastrophic engine failure. The water pump, tensioner should be done as preventative maintenance. While they are in there change the serpentine belt too.
