My white Insight has the same exact problem but is pealing all over. It started on the hood & that is were the biggest spots are located.
We can’t see the post that described “the same exact problem”. Could you tell us what problem you are having with your Insight?
We don’t know the other guy’s complaint . . .
Can we assume your clear coat is peeling?
If so, you’d be well advised to contact a reputable body shop
