2010 Honda CR-V - AC issue. It wasn't the fuses or relays
2010 CRV Honda LX A/c lows cold then blows hot…changed fuses and relays without positive results
Welcome to the forum…
The best thing you can do is take your vehicle to a shop and let a qualified mechanic that has all the proper tools to check the system out and let you know what the problem is… Then you can decide if you will do the repairs or pay to have them done…
But if you are determined to check it yourself, you need to hook up a set of AC manifold gauges and see what your head pressure (high side) and low side pressures are…
