mysteriously changes radio stations without touching controls
Is your radio self-contained, or is it controlled by other switches external to the unit?
A failing body control module can cause weird stuff. https://moduleexperts.com/5-common-symptoms-failing-body-control-module-bcm/
Can you change stations from the steering wheel? If so, those buttons or your clock spring could be starting to fail.
